Distributor Help Timing and Idle
Old Apr 9, 2011 | 10:02 PM
  #26
mouab18c1's Avatar
Default Re: Distributor Help Timing and Idle
You do know that timing affects it as well right? I say jump the ecu service connector and slap a timing gun onto it and make sure it's at 16*. Your idle is not fluctuating so it should be steady enough to adjust it.
Old Apr 21, 2011 | 03:01 PM
  #27
trevek10's Avatar
ran vac test everything pulled good vac// (everything is good) swaped ecu to double check
im going to swap iacv out and close TB a hair and re adjust the tps to .5 ....
well see what happens
Thanks again guys
Old Apr 25, 2011 | 09:19 AM
  #28
trevek10's Avatar
so im suspecting the problem with the dizzy is in the ignition system.. im going to replace the cap and rotor.. i was wondering if there is anything you guys recomend me checking or changing besides cap and rotor and spark plugs and wires
i was wondering if there is any difference in these parts 30102-P72-006 and 30102-P54-006
i looked up by dizzy stamp and it is td-68u : the reason i ask is because the first is obd 1 gsr part number and the other is obd1 b16 si and they are different in price. am i safe to use either?
[TD-68] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-73] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-84] OBD2 B16/GSR/ITR VTEC 1996-2001
ill try and post some pics to see if you guys think the cap and rotor is bad
Old Apr 25, 2011 | 09:39 AM
  #29
trevek10's Avatar
Old Apr 25, 2011 | 06:52 PM
  #30
trevek10's Avatar
thanks guys for replies
Old Apr 26, 2011 | 08:14 AM
  #31
JW racing's Avatar
Glad I could help ya narrow down the idle issue.
I got rid of most of my B stuff long long ago,but I think I still have one laying around...Let's try another dizzy and see how that one reacts adjustment wise.
Old Apr 26, 2011 | 02:12 PM
  #32
trevek10's Avatar
alright ya lets try it.. you going to be out working on kens anytime soon?
Old May 16, 2011 | 03:07 PM
  #33
trevek10's Avatar
bump for update
hondamyheart
May 12, 2016 12:08 AM
Kyogie12
Dec 18, 2011 05:48 AM
sythe21
Oct 21, 2011 05:30 PM
bassysingh
Oct 17, 2005 10:02 AM
ludedudesi
Feb 9, 2003 03:09 PM
