Dimmer Replacement ~ Equivilant Switch?
Old Aug 6, 2003 | 08:53 PM
integra-modder's Avatar
Default Dimmer Replacement ~ Equivilant Switch?
Im relocating my dimmer for my dash lights and need to put in a replacement (I want to be able to dim lights). The factory dimmer has a ground coming to it, positive 12 volts, and the output from the dimmer which feeds the interior lights.
I was thinking of using a potentiometer and then only having the +12 volts go in and the ~12-0 volts go out.
Was wondering if anyone knew and specific type of Pots, Trimmers, or Switches that would allow me to have dimming control over my guages from a 0-12 volt application. Best scenerio would be a click off, and then 0-12.
Thanks
Old Aug 7, 2003 | 05:12 AM
WOTTEG's Avatar
Default Re: Dimmer Replacement ~ Equivilant Switch? (integra-modder)
Try NKK switches. Larges manufacturer of switches in the world.
You can find your local dealer and have them ship you a "sample".
Old Aug 7, 2003 | 08:11 PM
Default Re: Dimmer Replacement ~ Equivilant Switch? (WOTTEG)
Do you know the name of a dimmer type switch which acts like a pot, varing the voltage from 100-0%?
Old Aug 9, 2003 | 12:43 PM
ttt
Old Aug 10, 2003 | 07:52 AM
anyone with knowledge of switches?
cmwalker
Jan 17, 2014 12:06 PM
Basically
Mar 6, 2005 08:58 PM
slammedef06
Jan 31, 2005 06:54 PM
wutangben
May 28, 2002 02:38 PM
