Does the dimmer switch affect dash lights?
Old Aug 12, 2012 | 03:43 PM
cmwalker's Avatar
Default Does the dimmer switch affect dash lights?
hey guys i just got done putting my dash in my integra, i couldnt find the plug for the dimmer switch but i didnt think it ws a big deal, now my cluster lights dont work, everything else is fine. whats your input? can anyone run outside and unplug their dimmer switch and tell me if your dash lights still light up...thank guys!
Old Aug 12, 2012 | 03:47 PM
cmwalker's Avatar
Default Re: Does the dimmer switch affect dash lights?
im looking at a wiring diagram right now and it clearly flows threw the dimmer switch, i just dont want to guess, not sure if it will just be the brightest with not option of dimming without the switch (what i assumed)
Old Aug 12, 2012 | 08:00 PM
el crapitan's Avatar
you need the switch to complete the circuit. no switch. no lights
Old Aug 13, 2012 | 08:01 AM
hbcrazy88's Avatar
found this out he hard way along time ago lol. like stated it HAS to be plugged in for any of your electrical on your dash to work.... im 99% sure this affects your heater also if i remember correctly
Old Aug 13, 2012 | 08:11 AM
cmwalker's Avatar
ok thanks guys!
Old Aug 13, 2012 | 11:38 AM
fcm's Avatar
fcm
Old Fart
As mentioned, the "Dash Lights Brightness Controller", [sometimes mistakenly called a dimmer switch] must be plugged in for most dash lights to work, [or the plug needs to be jumped, black to red] it supplies the ground, [through resistance] to the dash lights.
It has no effect on the heater, unless hbcrazy88 means the lights on the heater control panel. 94
Old Jan 16, 2014 | 06:52 AM
Johnoolo's Avatar
Explain exactly how I'd jump it and bypass it?
Old Jan 17, 2014 | 12:06 PM
hacker4991's Avatar
Get a paper clip and jump the cables he said
vartok
May 20, 2014 04:28 AM
Silvertune
11
Apr 15, 2012 09:20 PM
italianchooch88
Feb 13, 2008 01:45 PM
Jonathan_ED3
11
Aug 25, 2005 03:47 PM
Basically
Mar 6, 2005 08:58 PM
