GSR motor - OBD2 distributor on OBD1 car
I have a 93 hatch with an obd2 gsr and obviously the plugs on the distributors are different.
I dont want to buy an obd1 distributor so Id like to switch the wiring around.
1. does anybody have the pic or the diagram to line up the wires from obd2 - obd1? my wires are kindof fainted and i dont want to mix them up.
2. can you depin those wires on the dizzy? i dont see any way of doing that.
I was thinking about cutting the plug off and getting a universal waterproof socket from the terminal supply store.
Re: GSR motor - OBD2 distributor on OBD1 car (ham)
my car is runnig more than perfect with that setup.
all the colors are the same on obd1 and obd2 dizzy plugs.
use some cleaner on the wires to see them better...
if you can see than you can make it work.
Re: GSR motor - OBD2 distributor on OBD1 car (USDMej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">my car is runnig more than perfect with that setup.
if you can see than you can make it work.</TD></TR></TABLE>
how the hell did you depin those wires on the obd2 plug???
everything from the obd2 gsr engine harness plugs right up to your civics chassis harness. you just need at obd1 p72 ecu
Re: GSR motor - OBD2 distributor on OBD1 car (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug »</TD></TR><TR><TD CLASS="quote">everything from the obd2 gsr engine harness plugs right up to your civics chassis harness. you just need at obd1 p72 ecu</TD></TR></TABLE>
that was not the question at all. the only issue is the distributor plug. they are not the same.
this is a fully built turbo (obd2) gsr in my 93 hatch with a p72 running hondata.
you use can everything from the obd2 gsr. i had a 2000 gsr in my 94 and 92 hatch and i used the obd2 dizzy and injectors. seems like you must be using a different engine harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug »</TD></TR><TR><TD CLASS="quote">you use can everything from the obd2 gsr. i had a 2000 gsr in my 94 and 92 hatch and i used the obd2 dizzy and injectors. seems like you must be using a different engine harness.</TD></TR></TABLE>
thank you for the help but you are just making it more complicated. obd2 and obd1 distributors are DIFFERENT.
This is OBD1 (2 plugs)
This is OBD2 (1 plug) see the difference?
