dart build questions
Old Jun 27, 2008 | 09:46 AM
playaP's Avatar
Default dart build questions
i got a dart b18 with a eagle ls crank, grp rods, ross 84.5 low comp pistons.. the block is at stock bore 81-81.5 wichever it is and i am wondering if i need to resleeve or just bore it out to fit the 84.5s because the stock dart sleeves are already so thin..
Old Jun 27, 2008 | 10:03 AM
wright54's Avatar
Default Re: dart build questions (playaP)
Did you buy the block used or did you get it new. If you got it new then I would see if you can return it for the DART block that is 84.5mm bore. If not then take it to a machine shop and have them look to see if they can bore it out to 84.5mm.
Old Jun 27, 2008 | 11:54 AM
playaP's Avatar
Default Re: dart build questions (wright54)
i bought it used around a year ago and ive measured it and its 81.5 . ive put the tape measure on the top of the cylinder and it looks like 84.5 would leave the sleeves just paper thin so im guessing that i will also need new sleeves now. i just wasnt sure..
nengx07
11
Feb 5, 2009 07:24 PM
Death_to_Thieves
Nov 25, 2004 07:51 PM
_Endless_
Mar 11, 2004 06:37 AM
phiberoptik
Aug 27, 2003 10:19 AM
PainfulTeg
Nov 10, 2002 10:11 PM
