Damn car isn't running...Code 5.
Old Jul 3, 2002 | 12:35 PM
TodaSi's Avatar
Default Damn car isn't running...Code 5.
Okay, here is the story.
I had a 99 Civic Si with an ITR bottom end, and put it into my 92 Civic CX. I used an integra GS-R(obd II) wire harness, Kenji harness adapter, and programed P72 ECU. I installed a new timing belt, retainers, valves, because the stock belt broke.
Put it all together and put it in. Hooked up the CKF (white/red to C11, and Blue/red to C1, EVAP (yellow/black to another yellow/black for power), EVAP Solenoid wired to A20, Knock sensor to D3, and VTEC was already there.
Now the car won't run. It idles(actually good for my Spec C cams), but cuts out when I give it just the slightest amount of gas. Under any load it dies. The brakes are soft and won't hold a firm pedal. I re-used the CX's charcoal canister and ran 3 vacuum lines to it.
I'm getting a code 5 from the ECU. While the car was idling the check engine light was flashing as well (after about 5-10 min.) I changed the MAP sensor with a good one, but it still didn't run at all.
Vacuum lines are hooked up correctly.
I haven't a clue on what to do. I'm at my wits end. Is there anything I've missed?
Old Jul 3, 2002 | 03:50 PM
TodaSi's Avatar
Default Re: Damn car isn't running...Code 5. (TodaSi)
No help yet? please
Old Jul 3, 2002 | 03:57 PM
Spade's Avatar
5 MAP - manifold absolute pressure sensor
Old Jul 3, 2002 | 04:02 PM
TodaSi's Avatar
Default Re: Damn car isn't running...Code 5. (Spade)
Yep, got that part correct. Any suggestions on what else to check for?
Old Jul 3, 2002 | 04:45 PM
TodaSi's Avatar
Okay everyone, move right along....nothing to see here, no problems, everything is okay. Just me sitting here in the corner with a DUNCE cap on. Go ahead, nothing to see.
If you want to know what the problem was, well, lets just say the throttle angle sensor and MAP sensor connectors are the same size, shape and # of pins, but they have different color wires running to them.....funny thing huh?
Old Jul 3, 2002 | 05:02 PM
kenji's Avatar
25 Year Member
Chad!
Step away from the wiring and put your hands on your head!
(gotta say it with the NY cop voice)
-kenji
Old Jul 3, 2002 | 05:14 PM
TodaSi's Avatar
Default Re: Damn car isn't running...Code 5. (kenji)
ROTFLMAO!!!!!!!
No problem officer! Want a donut?
Old Jul 3, 2002 | 06:04 PM
sackdz's Avatar
HAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHA
*big breath*
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!! !!!!!!!!
You'll never live this one down Houghtaling!
[e] I think you are now an honorary member of we-todd-did racing
[Modified by sackdz, 10:05 PM 7/3/2002]
Old Jul 3, 2002 | 06:13 PM
TodaSi's Avatar
Default Re: Damn car isn't running...Code 5. (sackdz)
*big breath*
Wow, someone who can spell my name right
Now, we'll see who gets owned at Gingerman
Fraser1989
13
Apr 26, 2018 05:35 PM
toolbox21
May 28, 2008 04:02 PM
RotiEatter
Dec 4, 2004 09:08 AM
TodaSi
Jul 5, 2002 07:34 AM
TodaSi
Jun 23, 2002 09:53 AM
