Help with 99 Civic Si Engine Harness
I have a 99 Civic DX HB. I am putting in a GSR motor soon so I bought a 99 Civic Si engine harness off someone here so I didn't ahve to deal with the wiring. One of the plugs isn't on my stock harness so I dont know what it goes to. It looks like the typical Honda 2-wire plug but with only one wire and it is red/blue. It is close to the plug for power steering Here is a pic:
I also wanted to see if someone could verify the colors of the IACV plug and the 2-wire plug for VTEC Pressure Switch. Thanks a lot.
Re: Help with 99 Civic Si Engine Harness (RotiEatter)
the red/blue looks like it's for the knock sensor, but i'm not sure if obd2 harnesses have knock sensors.
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V power (hot in ON or START)
Evap Purge Solenoid Red A20
posted off http://tech.hybridgarage.com/t....html
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">Definitely knock sensor if only 1 wire going to it.</TD></TR></TABLE>Yeah the connector would be green if it was for the VTEC pressure switch...
Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">cool, anyone for the IACV?</TD></TR></TABLE>
Black/Blue (B23) and yellow/black (sensor voltage)
VTP:
Blue/black (c10)
Black, ground
Those are OBD2b ECU pinouts
Kabir/shawn, if you need the wiring diagram, I will sent it to you.
The others were right about the knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">the red/blue looks like it's for the knock sensor, but i'm not sure if obd2 harnesses have knock sensors.
posted off http://tech.hybridgarage.com/t....html </TD></TR></TABLE>
Those are OBD1 pinouts. IF you convert to OBD1, you can use that info.
VTP:
Blue/black (c10)
Black, ground
civcexcoupeblack
05-09-2003 06:13 AM
