Need some help/ideas Code 54 and 5
Old Jun 22, 2002 | 09:03 PM
TodaSi's Avatar
Default Need some help/ideas Code 54 and 5
Hi all,
Well I got my engine back together and dropped it in my car. Tonight I fired it up and idle sucked, and the engine died if I gave it just a little gas to keep it running. ECU kicked on a check engine light. When I check the codes, they were 54 and 5 (crankshaft sensor and MAP sensor)
All connections are good, check all vacuum lines, so I'm lost as to what else to check.
Car is 92 Civic CX, with Integra engine harness. Engine is a ITR block and Si head and tranny (basically put an ITR block in my 99 Si)
Any suggestions? Help would be greatly appreciated.
Old Jun 22, 2002 | 10:24 PM
salbaje's Avatar
Default Re: Need some help/ideas Code 54 and 5 (TodaSi)
which ecu are you using???
Old Jun 22, 2002 | 10:36 PM
TodaSi's Avatar
Default Re: Need some help/ideas Code 54 and 5 (salbaje)
P72
Found the problem. It's the c104 to c220 connector (CKF sensor and EVAP Purge solenoid valve) I have the c104 plug on the integra engine wire harness, but nothing to connect it to in the CX chassis harness.
So now I'm wondering what I should do next. Where do I connect the wires? What ECU plug pin #'s do they go to?
Old Jun 23, 2002 | 08:24 AM
1 2 NV's Avatar
what yr harness did u use??? i had no problems with my swap. built 98 GSR/ITR, using 96 GSR harness in 92 CX also.
Old Jun 23, 2002 | 08:34 AM
TodaSi's Avatar
Default Re: Need some help/ideas Code 54 and 5 (hondaatwsu)
Not sure what year.....but it's OBD-II
Old Jun 23, 2002 | 09:17 AM
1 2 NV's Avatar
i wish i could b more help chad. just dont know though. i plugged everything in fired it up. i had a VTEC code but then added 1 wire to the civic engine harness to the ECU.
Old Jun 23, 2002 | 09:53 AM
TodaSi's Avatar
Thanks for trying
I'll try to muddle through it. Aaaaaauuugh!
91whitecivic
Mar 6, 2011 10:06 AM
civickid03
19
Feb 4, 2009 03:51 AM
scuzz
Sep 21, 2008 04:50 AM
sivik2nr
Jul 17, 2004 07:28 AM
dre000
Jan 19, 2003 01:36 AM
