D16Z6 compression test...
From left to right, cylinders 1-4: 149, 149, 150, 148
the motor has 155,000 miles on it. I know it's good to have the numbers close to each other, but are the numbers low all together?
[Modified by Chris83179, 6:08 AM 8/5/2002]
the numbers are a little low but there close together so you should be ok they should be around 200+ psi did you check with the gas all the way down and the motor warm?
well, the motor was somewhat warm, but not that close to normal temp...
i did it with all the spark plugs loosened, and cranked it until the gauge stopped climbing.
what would the throttle position have to do with anything?
[Modified by Chris83179, 5:21 PM 8/5/2002]
slowexcoupe
Nov 29, 2009 07:30 PM
Skadaloz
Apr 8, 2008 10:02 AM
KB Tuning
Nov 24, 2004 07:31 AM
195, commpression, compression, compressions, crank, d16z6, motor, normal, numbers, plugs, psi, spark, stock, test, times
