Compression Test
Old Sep 14, 2001 | 08:31 PM
digitalspice's Avatar
Banned
Default Compression Test
210 psi in all cylinders on a GSR with 60.000 miles, how is this?
Thanks.
Old Sep 14, 2001 | 09:14 PM
MintyDip's Avatar
Default Re: Compression Test (digitalspice)
is it stock?
i doubt...
Old Sep 14, 2001 | 09:19 PM
Banned
Default Re: Compression Test (MintyDip)
Followed the procedures from C-SpeedRacing.com exactly and got 210psi across the board. Is that high for a stock motor.
[Modified by digitalspice, 1:09 AM 11/4/2002]
Old Sep 14, 2001 | 09:59 PM
FAST94GSR's Avatar
New User
that's good. motor sounds pretty strong still.
Old Sep 14, 2001 | 10:53 PM
OneThirtyEight's Avatar
Default Re: Compression Test (FAST94GSR)
thats real nice
Old Sep 14, 2001 | 11:03 PM
MintyDip's Avatar
Default Re: Compression Test (97blackteg)
I have never done a compression test...
i got a detailed instruction from http://www.c-speedracing.com , but i dont under stand when they say push the gas to the pedal and crank the motor......
Then carefully insert it into the first cylinder where the spark plug normally goes and hand tighten by turning the hose on the compression tester. You are now ready to crank the motor over. Have someone hold the compression tester while you press the gas pedal all the way to the floor, this is very important. While the pedal is pressed down, turn the ignition on and crank the motor over 5 times.
wut does crank refer to? sorry if its a dumb question, but i dont want to mess this up when i try it. crank as in turn on the engine 5 times?
[Modified by MintyDip, 12:04 AM 9/15/2001]
Old Sep 15, 2001 | 12:14 AM
ken's Avatar
ken
Crank the motor over, as in starting the motor. Although, You'll have the spark plugs and ECU disconnected, so it won't start, the starter will just crank (as in turn) the motor over. You let it turn over about 5-6 times and that's probably all you need.
Old Sep 15, 2001 | 12:51 AM
Tr0LL's Avatar
Default Re: Compression Test (SeaDawg)
I did a compression test on my 1st generation b16a after I finished swapping it in. I got 230, 225, 220, 230.
I know it's not suppose to vary more than 20psi from cylinder to cylinder, but is this ok?
It's a stock 1st gen b16a with ITR manifold. I took the intake piping and filter completely off (cuz of something else). I also disconnected wires going to each fuel injector and took out all the spark plugs and plug wires.
Old Sep 15, 2001 | 12:54 AM
Yyz's Avatar
Yyz
Mine had 200 in every cylinder. Is that good? I have a 95 GSR with 97,200 miles on it?
Old Sep 15, 2001 | 05:53 AM
VTECAcuraGSR's Avatar
Default Re: Compression Test (Yyz)
These are all good numbers. Obviously, as time and miles come the psi will come down due to wear. What you really care about is the variablity between cylinders. Like mentioned before, you do not want more that 10% between cylinders. So if the highest psi is 200, you do not want any cylinder below 180.
Old Sep 15, 2001 | 06:18 AM
PROFILES2000's Avatar
Default Re: Compression Test (VTECAcuraGSR)
175 180 180 180 after hitting 10,000 rpm all i need is a valve adjustment which i am getting today. oh and the reason it is so low is b\c i have a 99 b16 head on a 00 gsr block (yeilds about 9.8-1 compression)
nuy usually i am at 190 across
Old Sep 15, 2001 | 02:17 PM
Banned
Default Re: Compression Test (ProfileGsR)
Kewl, Wanted to get an idea of what the average was among the other members.
Couldnt beileve how easy this was to do and a shop wanted to charge $75.00 to do this.
Old Sep 17, 2001 | 08:42 AM
betsuni's Avatar
where can i get a compression tester, how much does it cost? i want to do this to my engine. thanks a lot!
Old Sep 18, 2001 | 01:18 PM
Yyz's Avatar
Yyz
Default Re: Compression Test (betsuni)
I got mine from sears for $25. It is probably not the best compression tester on the market but it does the job.
Old Sep 18, 2001 | 01:21 PM
krshultz's Avatar
Why do they want you to put the gas pedal on the floor?
Old Sep 18, 2001 | 02:26 PM
dustin's Avatar
Default Re: Compression Test (krshultz)
It is (trivially?) harder for the motor to suck air in with the throttle plate closed.
Dustin
Old Sep 18, 2001 | 06:40 PM
MugenEg6's Avatar
Just unplug the distributor and you will be fine
Old Sep 18, 2001 | 07:03 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Compression Test (MugenEg6)
No, no, no.
Pull the ECU fuse. Just unplugging the distributor only removes spark, you want to make sure you don't dump fuel in the cylinders while testing.
Old Sep 18, 2001 | 07:07 PM
MugenEg6's Avatar
Default Re: Compression Test (B18C-EJ1)
Ive gotten a accurate reading and i always leave the ecu plugged in along with the fuse
Old Sep 18, 2001 | 08:57 PM
MintyDip's Avatar
Default Re: Compression Test (dc2jdmhonda)
now im confused on wut to unplug.......
Old Sep 18, 2001 | 09:00 PM
B18C-EJ1
Guest
Posts: n/a
Just take out the ECU fuse. Do it how the Helms manual recommends.
Old Sep 19, 2001 | 05:50 PM
dustin's Avatar
If you leave the ECU fuse in, you dump tons of fuel in the chamber with no spark. You can get a lower reading this way because the extra gas gets rid of the oil seal. You also end up with a small amount of gas in your oil. In addition, your car is not going to want to start up directly afterwards because the combustion chamber will be dripping with gas... heh.
Dustin
Old Sep 19, 2001 | 06:41 PM
krshultz's Avatar
Default Re: Compression Test (dustin)
A-ha. Seems so obvious now.
--Karl, who is happy with 6% leakdown and 190-195psi compression...after 123K miles, 20 track events, countless autocrosses, and a lifetime of Mobil 1 since new
Old Sep 20, 2001 | 10:36 AM
betsuni's Avatar
thanks Yyz!
EdwinCheng
May 8, 2014 02:26 PM
teddy_dc2
Honda Civic (2006 - 2015)
Feb 21, 2008 08:24 AM
E dwinbon G
Dec 19, 2003 07:51 AM
bossman032
33
Jun 5, 2003 07:41 PM
wm5holla
Mar 23, 2003 03:39 PM
