D15Z1 swap
Old Mar 10, 2005 | 06:24 AM
LowDog's Avatar
Default D15Z1 swap
Hi. I got a 93' Civic VEi VTEC-E D15Z1 (90 hp) Think it's called VX in US but not sure.
*** u might has guessed... It's kinda slow.
What will i need to throw in a D16Z6 ESi/Si Vtec? (125 hp)
I'm not exactly the worlds best mechanic, so what other parts than the engine do i need
Hope u can help me.
Thanks in advance.
Old Mar 10, 2005 | 08:54 AM
thatbluecrx's Avatar
Default Re: D15Z1 swap (LowDog)
search dpfi to mpfi swap
or search for
d15 D16Z6
Old Mar 10, 2005 | 09:29 AM
dwnthehatch's Avatar
It's basically all plug and play except for the o2 sensor wiring. You will have to move 1 wire and that's it. You can use your existing axles, shift linkage and mounts, you will need to use the d16z6 P28 ecu. My instructions are here: https://honda-tech.com/zerothread?id=644434
Just follow the o2 wiring part. They other part is of no use to you since it's for the gsr secondaries.
Old Mar 10, 2005 | 12:01 PM
LowDog's Avatar
thnx dwnthehatch
Sounds 'easy' :- ) I“ll look for a nu ecu then.
singlecammin
Jan 3, 2011 08:35 AM
shredderkid322
Jul 13, 2010 09:42 AM
all_motor
25
Jun 3, 2007 03:44 AM
jackhunt321
Sep 29, 2006 10:06 AM
Ding
Oct 28, 2005 08:14 AM
