Custom brake line problem
Old Nov 30, 2007 | 11:31 AM
boost fed ls's Avatar
Default Custom brake line problem
I just completed a engine bay tuck and installed a adjustable porp valve which required me to run all new line to the rear as well. I went to bleed the brakes and they leak at at every fitting. I went over each one and tightend them to the max with verry little luck. My question is, is there any trick to flaring the line ends? Any input would be greatfull!!!!!
Old Nov 30, 2007 | 12:15 PM
hellakapps's Avatar
Default Re: Custom brake line problem (boost fed ls)
yeah it's called a double flare tool and just read the instructions, it can be a bi**h sometimes.......good luck make sure you get it right also!!!
BlitzSix
12
Jul 1, 2009 10:55 PM
beav
Nov 26, 2007 09:28 AM
JCracer723
Mar 9, 2007 06:52 AM
Pandahatch
Suspension & Brakes
May 22, 2005 11:28 AM
turbospool
Aug 10, 2003 11:38 AM
