ctr tranny???
Old Oct 2, 2006 | 09:13 AM
midnitesol's Avatar
Default ctr tranny???
just installed new clutch and noticed that passenger axle and half-shaft r both leaking oil can i just tap in the axle to get it to sit right and could it be that it wont go in gear cause the axle is not in all the way? thanks ahead of time for the replies!
Old Oct 2, 2006 | 03:46 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ctr tranny??? (midnitesol)
When are you having problems putting it into gear: when the car is running, off, or both?
Old Oct 2, 2006 | 08:41 PM
midnitesol's Avatar
Default Re: ctr tranny??? (Dogginator)
when the car is off it goes in fine but when on i have to force it in really hard but it doesnt grind and it still drives. thanks for any input!
Old Oct 3, 2006 | 03:47 AM
Dogginator's Avatar
Daisy... Daisy...
Since it is only difficult with the car running, your clutch is not fully disengaging. Try bleeding the slave cylinder.
Old Oct 3, 2006 | 07:08 AM
b18ek670's Avatar
your axle seals are probably leaking...
Old Oct 3, 2006 | 10:43 AM
midnitesol's Avatar
Default Re: ctr tranny??? (b18ek670)
i will try bleeding the slave cylinder and yeah my axle seal was leaking cause it was too full but wont get a chance to workon it till tomorrow i hope. will repost later. Thanks for the suggestions much appreciated!
dirvin7588
May 11, 2011 11:43 AM
vanmaster420
Mar 4, 2007 09:29 PM
midnitesol
12
Oct 2, 2006 10:32 AM
t0ekn3e
23
May 15, 2005 06:44 PM
EKtypeRhaTcH
Jan 20, 2005 09:20 PM
