ctr tranny ???
ctr tranny ???
just installed new clutch and noticed that passenger axle and half-shaft r both leaking oil can i just tap in the axle to get it to sit right and could it be that it wont go in gear cause the axle is not in all the way? thanks ahead of time for the replies!
Re: ctr tranny ??? (midnitesol)
i mean can i tap the axle in without having to take it apart again? i know i have to unbolt the halfshaft from the block though.
slightly confused about what you are asking. You need to tap the axles in all the way. You can use a piece of wood and a hammer to tap them in. You should feel a little click when they go in all the way. If they are in all the way, and still leaking, then you may need new axle seals.
Re: ctr tranny ??? (sol2hatch)
i mean do i have to disassemble the whole axle like the axle nut and the lower control arm or can i tap it in assembled?
you dont need to take everything apart to tap the axle in, but if the seal is messed up or pushed in, then you will have to take it all apart again
cool thanks. also its not that i cant get in gear i just have to force it in really hard could it be that? Good luck with ur swap
i'm talking a d-series here but when i swapped my tranny i didn't have my passenger's side axle in all the way, like a 1/8-1/4 inch from all the way and i got about 100 feet before being in gear was the same as neutral, did not move. try tapping them in and go from there
jdm_vtec
10
05-01-2007 06:58 AM
