crap
Old Oct 27, 2002 | 01:10 AM
ion_four's Avatar
Default crap
sorry to be a thread *****, but I'm really needing some help here...
To summarize some other posts: Installed MSD 6BTM, car ran for a few minutes, then died. The car would turn over, but I am getting no spark, so it doesn't start. I checked everything and came to the conclusion it was the ICM (ignitor). I replaced the ignitor and it still won't start. I traced the Ignition Input signal wire back to the ECU and when someone is turning the motor over there is very little voltage (either 0.08v or 0.8v, I forgot :hammer coming out of pins A21/A22 on the ecu(they are red with green stripe wires, and become a yellow with green stripe sometime before going to the distributor.
Can someone verify what this voltage at the ecu should be?
Anyone know of a good way to test the coil, aside from resistance? Should I take it out and hook it up to the battery and try to get it to arc with a ground?
I'm really taking it in the butt here, any help would be awesome. I can't afford to bring it into a shop now...
Old Oct 27, 2002 | 03:16 PM
ion_four's Avatar
Default Re: crap (ion_four)
ttt, anyone? I'm on my way to buy a new coil...good idea?
Old Oct 27, 2002 | 06:25 PM
ion_four's Avatar
It seems it was the coil. Good thing, since I didn't know if that would fix it until after I installed it.
Thanks for all the help guys.
nitroice40
Mar 13, 2022 11:27 AM
scUba-stEve
Dec 18, 2004 10:28 AM
drnovascotia
26
Aug 16, 2004 05:02 PM
Heat Rave R
Feb 17, 2003 07:35 PM
wanttorace
Oct 5, 2002 10:31 AM
