Check engine light on??????
Old Oct 27, 2002 | 05:36 PM
LS-T's Avatar
New User
Default Check engine light on??????
My check engine light came on today and i have no idea what is the cause.
I went over briefly to a mechanic shop and he did a quick diagnostic test on it. The mechanic said that my engine missfired the 1st 2nd and 4th times ("cylinder wall?). He used a lil computer handheld device.
HELP! Any guesses what is the problem.
My turbo kit arrives this coming week, any suggestions on whether or not I should install the kit? THANKS
Should i do a compression test? Maybe my internals are bad?
any advice would be much appreciated
marvin
Old Oct 27, 2002 | 05:45 PM
ImportHatch's Avatar
Default Re: Check engine light on?????? (Armani692)
see what codes its throwin first.
Yager-
Old Oct 27, 2002 | 05:48 PM
LS-T's Avatar
New User
Default Re: Check engine light on?????? (ImportHatch)
Yager-
i don't remember what it reads on his lil device but i recall 1st 2nd 4th missfire and something cylinder wall...do you know what thats about?
Old Oct 27, 2002 | 06:26 PM
Koori's Avatar
Okay, my check engine light came on for no reason too.. After I ran Compression, Leakdown and all the tests I could think of.. This is what the problem was, I didn't screw my gascap down good enough.. After 3 trips, the light resets.. Could be something supid like that. I was pissed as hell but at least I know my car runs well.
Old Oct 27, 2002 | 07:35 PM
B00ST2nR's Avatar
Default Re: Check engine light on?????? (Hadji)
just the code yourself and it will throw the code.
goto: http://www.c-speedracing.com and goto FAQS on the very top and it will tell you how to jump your wire. It will throw a code and the site will tell you what the problem is...
jdmkidd23
Mar 5, 2010 08:09 AM
lilmoney145
Feb 5, 2003 06:48 PM
LS-T
Oct 27, 2002 05:32 PM
LS-T
Oct 27, 2002 09:40 AM
