Crankshaft Position Sensor (CKP)!
OK.................I am the one currently working on the car...........I have tested all the wires from the distributor back and they are all within spec. The only one I am concerend about is the yellow green coming out of the distributor...........I did a continuity test on this and it read 1600 on the multimeter. I did a continuity test on my car on the same wire and it only read 621 on the multimeter........thats a difference of a 1000. Does anybody know what the yellow green Ignition Input Signal wire does...........like how is it pertinent to this whole CKP situation? I am not sure why it runs the way it does when the sensor is within spec..........any ideas are welcome
weird, my JDM 95 b16a2 didn't have one. I was even running a 99 JDM ITR ecu. I'm pretty sure the jdm engines don't have it. my 00 JDM ITR doesn't either........
**talking about CPS**
[Modified by Akira-R, 5:34 PM 8/6/2002]
Are you sure it is just 4 long blinks? That would be code 40 and there is no code 40.
http://tech.hybridgarage.com/tech/codes.html
[Modified by Mad_hatter, 11:02 AM 8/7/2002]
Its four short blinks code for Crank Position Sensor. I am checking the voltage readings off of the 3 different sensors inside the distributor right now...............as somebody else had mentioned in a private message.......maybe the ecu isn't getting a good "waveform" to trigger off of.
aviator.sm
Engine Management and Tuning
Jul 26, 2018 12:10 PM
JBirch_97Prelude
Jun 25, 2006 12:31 PM
spettinger
Sep 28, 2004 10:19 AM
