Could this be a ground issue?
Old Oct 27, 2005 | 06:32 AM
JODYG35950's Avatar
Default Could this be a ground issue?
Anytime I have moderate wheel hop (for instance when I grab second gear), I get a check engine light. It turns out to be like 5 codes including TPS, Fuel Supply, Map, IAC, and Coolant temp sensor. What could cause this? During no other time will these codes come on. Its a B18A in a 91 CRX. All sensors appear to be pluged in tightly and correctly.
Old Oct 27, 2005 | 07:50 AM
snatch's Avatar
Default Re: Could this be a ground issue? (JODYG35950)
Could be I suppose. Try cleaning or replacing the ground from valve cover to the chassis, and especially the one from tranny to chassis. See if that helps. Should be a 10 minute job, and cheap/free to do. With that old of a car, it certainly wouldn't hurt anything to spend 10 mintues on doing that.
Old Oct 27, 2005 | 07:54 AM
drdisco69's Avatar
Yeah, check the ground on the thermostat housing, it grounds the ecu and several sensors. Make sure it's clean and tight.
Jfrazer22
Jan 13, 2019 04:17 PM
D-seriousBis
Apr 11, 2013 05:07 PM
civicef990
Nov 25, 2011 06:53 AM
carlveitschegger
Nov 10, 2008 09:36 AM
Civicse
17
Mar 8, 2005 05:39 PM
