correct way to adjust for idle?
allright been having some issues with low idle under 500rpm most of the time weird thing is car does not shake or dies..yet.... allready found alot of threads on this but not consistant on how to adjust it.. timing is checked and correct.. iacv is cleaned.. no vaccume leaks..
can someone tell me the CORRECT procedure to adjust idle?
is it .....
1. get car to temp
2. turn off and unplug iacv
3. turn car on and adjust idle screw to 750+/-50 rpm
4. turn off car and reset ecu
5. plug iacv and start car
is this the correct way to do this?
jdm b18c obd2
is it .....
1. get car to temp
jdm b18c obd2
the right way is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out »</TD></TR><TR><TD CLASS="quote">1. get car to temp
2. unplug iacv
3. adjust idle screw to 750+/-50 rpm
2. unplug iacv
For USDM OBD-1 B18C1, you adjust for 450 to 500 rpm with the IACV unplugged. I wonder if JDM is that much different?
Then you plug in IACV, reset ECU, start car with no throttle, let it idle for ??? minutes.
how about a b16 with1995 Cx Hatch
-b16a swap
-CTR pistons
-Comp Cam Stg. 2's
-Omnipower Valvetrain
-Skunk 2 cam gears
-Skunk2 pro1 intake and 68mm TB
-Vibrant header
Engine/Tranny was TOTALLY rebuilt 10k~ miles ago
-Spoon N1 exhaust
-Working a/c
-Didnt come factory with p/s
-b16a swap
-CTR pistons
-Comp Cam Stg. 2's
-Skunk 2 cam gears
-Vibrant header
-Spoon N1 exhaust
-Working a/c
Is Car OBD2 Compliant? If so the only way to set the idle is with a HDS or go through the prescribed idle relearn program. It's not hard, Talk to your nearest Honda Pro for the correct info.
as Jim sayd with the iacv unplugged you adjust the idle to 450-500; then whn you plug it back the iacv will adjust to the preset idle (stock 700-800). Remember the iacv can only add air not take away
Mr. LS VTEC
Oct 25, 2006 05:43 AM
