Coolant loss
Old Aug 9, 2002 | 08:12 AM
SpoonCivic's Avatar
New User
Default Coolant loss
Hi,
I recently posted a topic of how my engine constantly overheats. I went thru and changed the thermostat, boguht a C&R Radiator..and it still seems to overheat.
The peculiar problem is that every morning, im having to top up coolant in the overflow tank, however there is no apparent leaks on my garage floor or anywhere underneath the car. I have air bled the system several times, just to ensure that there are no air bubbles in the system.
Another note is that before I had my engine built (bored to 84mm, resleeved) this problem was not occuring.
If anyone could help me on this situation it would be great..because I cant install my standalone until this problem is diagnosed.
Old Aug 9, 2002 | 08:48 AM
builthatch's Avatar
MiG-21 superfan
Default Re: Coolant loss (SpoonCivic)
compression to cooling system leak and/or coolant to CC leak....caused from improper deck job, head mating surface irregularities, blown HG, etc, etc...do a leakdown and see what happens with that. The probable reason for the missing coolant is consumption- your car is eating it. good luck
Old Aug 9, 2002 | 10:33 AM
IlikeTODA's Avatar
Like he said, do a leakdown check and see where the air comes from.
Thanks, J
Old Aug 9, 2002 | 05:06 PM
SpoonCivic's Avatar
New User
Default Re: Coolant loss (IlikeTODA)
thanks guys
Hoopdie91
Apr 3, 2016 06:15 AM
Panoply
Aug 12, 2010 08:40 AM
Uncle Ben's
Mar 25, 2010 10:27 AM
ekferio
Mar 31, 2006 10:22 AM
alpha
Aug 19, 2005 06:33 PM
