losing engine coolant
Old Mar 22, 2006 | 06:40 AM
ekferio's Avatar
Default losing engine coolant
i noticed the coolant level keeps getting lower in the overflow tank, so i had the dealer checked. They did a pressure test and flush the cooling system but found no problems whatsoever. I did not see any coolant mixed in with the oil. What else is there to check?
Old Mar 30, 2006 | 09:59 PM
Green Lude 93's Avatar
Default Re: losing engine coolant (ekferio)
bump for me having the same problem. no visible leak on freshly built motor but the overflow seems to need filling once a month.
Old Mar 31, 2006 | 01:00 AM
Ruben19's Avatar
i have the same problem.
but the car dont overheat and no leaks.
i think is normal.
because of the temperature
Old Mar 31, 2006 | 01:41 AM
Takumi Fujiwara's Avatar
Default Re: (Ruben19)
when you've driven your car for a while where it heats up pretty good, can you smell any coolant in the cockpit?
Old Mar 31, 2006 | 10:22 AM
ekferio's Avatar
it was air trapped in the cooling system, i had it "burped" and never lost coolant again. But now my heat is not hot enough like it used to be, having it checked next week
Uncle Ben's
Mar 25, 2010 10:27 AM
732xghost
Dec 22, 2006 07:22 AM
hondaracin24
May 11, 2006 08:56 PM
jvonb
Dec 2, 2005 03:15 PM
SpoonCivic
Aug 9, 2002 05:06 PM
