Coolant leaking....?
Old May 7, 2013 | 10:08 PM
cd5_2NR's Avatar
Default Coolant leaking....?
I noticed small amounts of coolant leaking randomly from the driver side....it only happens after the cars been parked and sitting for a while....not a big amount but enough to notice...I pulled the bumper and tried to locate the source but cant seem to see anything...is it just overflow or does anyone have any ideas...
Car is 99 Civic Si
Old May 8, 2013 | 05:18 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Coolant leaking....?
Could be coming from anywhere. Locate the source. And I don't know why you would have to pull the bumper to locate a coolant leak.
Old May 8, 2013 | 05:23 AM
HondaPartsHero's Avatar
Technical Hero
Drivers side could be water pump, a line dripping down the block or the radiator drain ****. If you can rent a pressure tester from autozone or advance that would be the easiest way.
Old May 8, 2013 | 11:59 AM
cd5_2NR's Avatar
Thanks....bumper was off because I was repainting fog light covers and cleaning it....
Ill check it out...water pump and timing belt r new....maybe a few months
Old May 8, 2013 | 06:08 PM
fcm's Avatar
fcm
Old Fart
If it is a stock rad, check all around the top and bottom "tanks" where they are "crimped" to the rad, and NO, this is not a good fix, a temp. fix in an emergency maybe...
Size:  10.2 KB 94
Old May 13, 2013 | 06:30 PM
Tyler Dirden's Avatar
I am Jack's...
Driver side coolant leaks are almost always water pump. These are very dangerous as they will quickly take out the timing belt. Pull the valve cover (very easy, 4x 10mm nuts and a couple hoses) then the upper cover. Peek inside for wet or sludgy belt dust/ antifreeze, any signs require instant attention.
synaps3
Mar 7, 2009 11:39 AM
klion22
May 27, 2008 12:28 PM
isaacEK
Aug 28, 2007 01:16 PM
Allstar
Feb 26, 2003 05:55 PM
redsled00
Jan 22, 2003 07:40 AM
