Coolant Leaking. Car overheating
My car has been leaking coolant for awhile now. I have been just pouring more and more water into the radiator. Now it's getting to the point where everytime I drive I notice a BIG puddle wherever my car sits. I've replaced the radiator(did it about 4 weeks ago.) My car is slammed, so that may be the problem? Do I need a new radiator?
I jacked it up and looked where it was leaking and couldn't see much because of the plastic guard on the bottom of the bumper. It is leaking on the front part of the driver's side somewhere I know that. Can anyone help me out?
Re: Coolant Leaking. Car overheating (isaacDC)
Remove the plastic part and see if you can see anything. Check around the waterpump to see if it is leeking from there.
Ali
Ali
Re: Coolant Leaking. Car overheating (PrinceAli132)
check all ur lines. i remember that in my ek that there was a hole in the hose/line. and just replaced it. it was right next to my thermostat and connected to the back of the block.
Re: (isaacDC)
Water pump is located on the drivers side of the motor. It is a little to the right of the drivers side motor mount and a few inches down. You will not see it due to the fact that the timing belt covers (black plastic) covers it.
If it is leaking in the front of the motor, check the coolant lines and maybe headgasket.
Ali
Ali
tossnupweight
12-07-2003 12:12 PM
