compression test
I don't understand your question really, but a compression test is used to test the condition of the rings mainly, and the leakdown test is to test the integrity of the head.
Sorry, I was looking to see if my rings were tosted or what. My motor was built but due to some problems I think the new rings I put are no good. Are you sure about the leak down? I was told you can tell if your rings are gone that wayalso.
i know to test the oil rings out you put two table spoons of oil in the cylinders and do a compression test, if the numbers increase significantly, then your oil rings are no good. but if they stay the same then you are ok. good luck, gloria
gooblinn258
May 30, 2014 12:20 PM
humboldt_skim
May 31, 2008 08:18 AM
