compression test
Old Aug 15, 2003 | 02:26 PM
DxTrix's Avatar
Default compression test
Any one know how to check the compresion to see if my piston rings are tost besides by doing a leak down. Please help
Old Aug 15, 2003 | 03:18 PM
R6Elmo's Avatar
Default Re: compression test (DxTrix)
I don't understand your question really, but a compression test is used to test the condition of the rings mainly, and the leakdown test is to test the integrity of the head.
Old Aug 15, 2003 | 03:29 PM
DxTrix's Avatar
Default Re: compression test (R6Elmo)
Sorry, I was looking to see if my rings were tosted or what. My motor was built but due to some problems I think the new rings I put are no good. Are you sure about the leak down? I was told you can tell if your rings are gone that wayalso.
Old Aug 15, 2003 | 03:57 PM
chictunner97ex's Avatar
i know to test the oil rings out you put two table spoons of oil in the cylinders and do a compression test, if the numbers increase significantly, then your oil rings are no good. but if they stay the same then you are ok. good luck, gloria
Old Aug 15, 2003 | 04:23 PM
tegmech's Avatar
https://honda-tech.com/zerothread?id=581420 this should help
Old Aug 15, 2003 | 04:58 PM
DxTrix's Avatar
Default Re: (tegmech)
Thanks tegmech...Thats what I thought I had to do.
gooblinn258
May 30, 2014 12:20 PM
marco562
10
Nov 19, 2012 10:59 AM
humboldt_skim
May 31, 2008 08:18 AM
vinuneuro
Apr 25, 2007 10:13 AM
silverboost
Nov 8, 2005 01:01 PM
