Compression test results.. you are not the father
Whats up guys, just did my compression test and well.... things don't look good.. lmk what you guys think!
210
160
150
210
What should be my next steps????
210
160
150
210
Re: Compression test results.. you are not the father
Do cylinder leak down tests to pinpoint where compression is lost. My guess would be a bad head gasket with two adjacent bad cylinders.
UPDATE: did oil change -which was super gross oil.. change the spark plugs did another compression test
210
190
190
210
I think anything above 180 is good to go correct?
Pretty weird what a little freshin up can do!
210
190
190
210
The Grumpiest
That looks much better but the same 2 cylinders are still suspect. If it were me I wouldn't stop there. Did you do a leakdown test?
Did you do a wet compression test ?
Or dry ?
If not, try a wet test in #2 and 3 cylinders...
If compression rises, you need compression rings...
If not then continue with any other suggestions.
Hope everything works out.
Or dry ?
here silky chemical leakdown tester
http://www.amazon.com/UVIEW-560000-C...7818167&sr=8-5
when you use it if the chemical turns a different color youll know if your headgasket is blown its somewhat pricey but they do work
what engine is this? if its a b7 i'll defiently say headgasket being that the b7 is known for poor cooling efficiency between cylinders 2 and 3
Sol to Sol
Is your exhaust manifold cracked in the center?
Thats how my Dads D16 lost 2 exhaust valves on the highway. (in #2 and 3) Tho I bet its the gasket too..
Also, I think I got my LDT from Harbor Freight, for a couple 20s.
humboldt_skim
05-31-2008 08:18 AM
