smoke coming out of valve cover breather
i have a 95 lsvtec turbo setup, i have a crome chipped ecu that works fine, my vtec wasnt working before and now i have it working but when i start my car smoke comes out of my breather on my valve cover, and when i drive it my car smokes a lot out of the exhaust. i dont recognize the smell and it is like white to blue tinted smoke
Re: smoke coming out of valve cover breather (ganjasnack)
the smoke from the breather is blow by, check ur compression, and do a leak down test, its normal to have blow bym but if its just idleing with a steady sream of smoke theres a problem
Re: smoke coming out of valve cover breather (DrivenMC)
no overheating or change in oil but i did do a compression test all the way around and cyls 1 2 and 4 had 184 PSI compression and cyl 3 had like 60, and when i put some oil in the cylinder it didnt change at all, to my understanding that means that its either the head gasket, valve seals or valves. I took my head off and the number 3 cyl is all black and oily, i think it is the seals.
lunareg
08-22-2010 03:31 PM
Redprelude98
30
07-21-2009 01:21 PM
00ITR #543
06-21-2002 12:56 PM
