compression check question?
Old Sep 18, 2005 | 04:17 PM
insomniac791's Avatar
Default compression check question?
I am just wondering why does it matter if the motor is cold or at operating temps when you do a compression check? I checked it when the motor is cold and I am getting weird results.
thanks
Matt
Old Sep 18, 2005 | 05:03 PM
o5mar1's Avatar
i think its because at operating temp. the pistons expand and may give you false readings
Old Sep 18, 2005 | 05:16 PM
Chiovnidca's Avatar
Default Re: compression check question? (insomniac791)
It should be checked with the motor warmed up if possible.
Old Sep 18, 2005 | 06:39 PM
mmuller's Avatar
Mad Scientist
Default Re: compression check question? (Chiovnidca)
yep, so rings/pistons are expanded to the op. temp.
Old Sep 18, 2005 | 07:26 PM
ok I was just wondering. Once I get my car running again I will check the compression when it is warmed up. Thanks
Matt
Old Sep 19, 2005 | 06:23 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 &raquo;</TD></TR><TR><TD CLASS="quote">I am just wondering why does it matter if the motor is cold or at operating temps when you do a compression check?</TD></TR></TABLE>Cold engine cranks at lower rpm with the starter. Warmed-up engine is more consistant, & more representative of compression while running. Oil has been circulating so that's closer to operating conditions too.
It'll work sorta OK on a cold engine (if you can't get it started), but like you say, check it again after you get it running.
Old Sep 19, 2005 | 12:36 PM
well when I checked the numbers last night they were
225,180,225,225
today I FINALLY got the car running again and checked them aftedr the car was at operating temps
and it was
225,225,225,225
So I guess all is good thanks
Matt
bluenc-87
Jan 30, 2010 01:46 PM
astralshadow
Jul 7, 2008 02:57 PM
JDM_EK_JOE
Oct 22, 2007 07:11 PM
boostedinteg03
Apr 11, 2003 12:47 PM
