Coilovers on stock shocks??
Old May 11, 2004 | 11:15 AM
SweetSnowGurl's Avatar
Default Coilovers on stock shocks??
K so I just got a 97 Civic ex coupe. I was gonna buy some Ground Control Coilovers. My question is do I need to buy shocks at the same time as the coil overs?? Or can I get the new shocks later on?? Sorry I"m a newbie and still learning the basics. Thanks for your help!
Old May 11, 2004 | 11:29 AM
spaceman's Avatar
Default Re: Coilovers on stock shocks?? (SweetSnowGurl)
you should be able to use stock shocks
Old May 11, 2004 | 11:31 AM
Deluzional's Avatar
Well first off, ground control shouldnt be considered a coilover, but adjustable springs . Depending on how low your ride will be will determine if you need aftermarket shocks, but imo I would do it all right the first time
Old May 11, 2004 | 05:57 PM
Mr_CRX's Avatar
Default Re: Coilovers on stock shocks?? (Deluzional)
I've riden in a 90 integra lowered moderately with GC coilovers or "adjustable springs" and stock shocks. It rides fine. Just dont dump your car on stock shocks.
If you cant afford the shocks at the same time, you should be okay as long as you dont lower it too much. However, its a real hassle having to take the shocks/coilovers out again to swap out the shocks. It's up to you, but I would rather do it all at once just to save work.
Old May 26, 2004 | 08:51 AM
BlackLS96's Avatar
Default Re: Coilovers on stock shocks?? (Mr_CRX)
So lets say that you do drop the car about 3" or in a 96 teg on 16" rims a drop till the fender is right on the tire, on stock shocks it rides pretty decently but would you guys recommend to go with KYB r2 or AGX's? I plan on doing autocross in the future. Thank you
Old May 26, 2004 | 08:58 AM
mmuller's Avatar
Mad Scientist
Default Re: Coilovers on stock shocks?? (BlackLS96)
yeah, as sayd above you'll be fine for the time being, just dont be a lowrider.
have mine lowered almost 2 inches on stock schocks and it rides fine
Old May 26, 2004 | 01:13 PM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackLS96 &raquo;</TD></TR><TR><TD CLASS="quote">So lets say that you do drop the car about 3" or in a 96 teg on 16" rims a drop till the fender is right on the tire, on stock shocks it rides pretty decently but would you guys recommend to go with KYB r2 or AGX's? I plan on doing autocross in the future. Thank you</TD></TR></TABLE>
I love my AGX's
Old May 26, 2004 | 03:35 PM
APEX CRX's Avatar
Default Re: Coilovers on stock shocks?? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yeah, as sayd above you'll be fine for the time being, just dont be a lowrider.
have mine lowered almost 2 inches on stock schocks and it rides fine</TD></TR></TABLE>
and don't forget to trim the bump stops
Old May 27, 2004 | 07:36 AM
NextGenRacing's Avatar
I went with AGX on the front and GR-2 in the rear, you'll get a better spring rate setup. Also, don't forget to get a good front & rear camber kit, or you'll slope the tires.
Good luck,
Old May 27, 2004 | 08:44 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Coilovers on stock shocks?? (NextGenRacing)
you'll be fine for a little while on the stock shocks. like everyone else has said, lower the car just enough, not too much. then, just save up for some good aftermarket ones.
Old May 27, 2004 | 11:56 AM
turbohondask's Avatar
Default Re: Coilovers on stock shocks?? (vtecb20coupe)
3 inch is very low. It can blow the shocks out if you bottom out a lot.
Old May 27, 2004 | 05:48 PM
dfoxengr's Avatar
Default Re: Coilovers on stock shocks?? (doublejz)
just get new struts right now so you dont have to take them apart again later.
ady2glude707
Dec 14, 2011 03:27 PM
93CX
12
Jul 13, 2003 12:59 PM
MiracleWhip
13
Jul 8, 2003 11:12 AM
RICEBURNER1406
Mar 22, 2002 07:01 PM
hobo79
Feb 19, 2002 06:55 AM
