Code 61 P0133
Old Jun 1, 2013 | 04:13 PM
Brunoboy's Avatar
Default Code 61 P0133
Hi guys, I have a 99 ek hatch with a 00 b16a2 swap complete with wiring harness and ECU. I have the slow response code right now and I have changed the front o2 twice and tried changing the ECU already. I just got done bringing it to the Exhaust shop with no sign of any leaks. I'm stumped and need to get this bar'd in two weeks. Dc headers are the only mod besides an intake. Timing has been checked and is good. Why would this code keep popping on?
Old Jun 1, 2013 | 11:01 PM
nub's Avatar
nub
Default Re: Code 61 P0133
P0133 is pretty much reset the ecu, see if the code comes back and if so replace the sensor.
It could be a bad connection between the sensor and ecu. Try checking resistance on the white O2 wire, on the harness side, with the sensor disconnected to ecu pin C16 also unplugged. There's not a "value" on this reading that I know of. You normaly check it for continuity or signal voltage.
Since you're not getting an O2 heater code you could do the the same test on the blk/wht wire to C1 as a referance.
Old Jun 2, 2013 | 12:20 AM
Brunoboy's Avatar
I have reset this thing numerous times with it always coming back. =\ what am I checking voltage for and what's the value supposed to be?
Old Jun 2, 2013 | 08:30 AM
nub's Avatar
nub
Not voltage, resistance.
If you have one or know somebody who does you could also try another known working ecu.
Old Jun 2, 2013 | 08:02 PM
Brunoboy's Avatar
I tried another ECU already, that one last tree times as long as mine before the code comes on again.
Old Jun 3, 2013 | 01:52 PM
Brunoboy's Avatar
Timing is in check as well. Any other advice? I need to BAR in less than two weeks
Old Jun 3, 2013 | 03:16 PM
slowcivic2k's Avatar
Replace the O2 Sensor, the PCM has determined that the rate of change on the front O2 is too slow, indicating a defective catalyst. replace the O2 sensor.
Old Jun 3, 2013 | 05:41 PM
nub's Avatar
nub
What brand an part number are you using for the replaced O2's?
You've said you replaced the O2 more than once and the ecu. Those are two of the three items needed for the circuit. The third is the wiring.
I'm not going to quote myself again...you need a digital multimeter and need to know how to use it. If you don't have a meter take the car to someone who can trouble shoot electrical systems...or keep replacing items randomly.
Old Jun 5, 2013 | 12:29 PM
Brunoboy's Avatar
I'm using a denso plug and play sensor. I'll work on the wiring and check it out.
Old Jun 5, 2013 | 12:30 PM
Brunoboy's Avatar
I've replaced the front sensor twice with the same code....
Old Jun 8, 2013 | 09:05 AM
Brunoboy's Avatar
Is this considered frayed or is it how it's supposed to be ?
Brunoboy's Avatar
FYI that's the o2 harness
Old Jun 8, 2013 | 12:00 PM
Brunoboy's Avatar
Bump it seems to be an insulator wire.... Any other ideas?
Old Jun 10, 2013 | 01:27 PM
You will need to fix that with a silver grade solder. Any corrosion in the signal circuit could produce that code. A O2 sensor stuck lean code is more likely with a chafed/damaged harness.
Old Jun 25, 2013 | 01:33 AM
Brunoboy's Avatar
I've completely changed the engine harness with a new working harness. No exhaust leaks, new sensors , two ecus, and I still get the code..... Wth can it be now -___- anyone think its the DC headers placement of the o2 sensor? Where does the oem o2 sensor sir on the stock header ?
Old Jun 26, 2013 | 09:10 AM
Brunoboy's Avatar
Bump bump bump
91GS-R in Vegas
Dec 20, 2007 04:55 PM
95_red_dc
Sep 11, 2006 06:32 AM
Gimp
Mar 4, 2004 02:14 PM
hondacivic4g
Mar 2, 2002 08:16 AM
