Error code question
Old Mar 3, 2004 | 06:47 PM
Gimp's Avatar
Default Error code question
Hi there, i've been surfing this forum for a while now and thought that someone here might be able to help me.
I drive a 1989 Civic Si. I keep getting 2 error codes thrown by my ECU. I get a code 1 which is the 02 reading and a code 20 which is the ELD. Does anyone have any experience fixing these problems?
*I have replaced my 02 sensor 2 times and checked the wiring from the sensor to the ECU and there is a good connection.
Thanks for any help.
Old Mar 3, 2004 | 07:02 PM
Redline130's Avatar
Default Re: Error code question (Gimp)
After you replaced the O2, did you reset the ecu?
Old Mar 4, 2004 | 01:39 PM
Gimp's Avatar
Default Re: Error code question (Redline130)
I reset the ECU both times i replaced the 02 sensor. I got the same result each time.
Old Mar 4, 2004 | 02:14 PM
Waachback's Avatar
It should be easy to fix the o2 sensor code. Just check if its in right and if the wire is cut. Also check the wiring to your ecu.
fryguy190
Mar 16, 2008 10:21 PM
91GS-R in Vegas
Dec 20, 2007 04:55 PM
kimo98GSR
Jun 30, 2004 09:51 PM
K20EG
Nov 17, 2003 07:12 AM
