OBD-0 PR3 ecu Code 2?
Old Nov 19, 2007 | 11:03 PM
91GS-R in Vegas's Avatar
Default OBD-0 PR3 ecu Code 2?
I've been searching throughout many different forums but all lead me to the same answer... "code 2 does not exist!" I'm getting a code 2 on my ECU even after resetting multiple times. Does anyone here know what code 2 is so I can fix it?
Chasis- 91 DA9
ECU- OBD-0 PR3
Engine- JDM B18C
Signed,
Frustrated!!!
Old Nov 21, 2007 | 04:25 PM
Default Re: OBD-0 PR3 ecu Code 2? (91GS-R in Vegas)
HELP!!! Anyone!?!
Old Nov 21, 2007 | 06:25 PM
Brice.Hayden's Avatar
It's your O2 sensor a code 1 is the one O2 sensor the code 2 is the 2nd O2 sensor
OBD0 is the only version that requires 2 o2 sensors in the primaries of the exhaust manifold.
Old Dec 20, 2007 | 02:41 PM
StrobeWylan's Avatar
In my experience not all oxygen sensor codes mean a bad sensor. Lots of times something else causes a bad fuel mixture and throws the code. Check out this link:http://www.mr2.com/TEXT/O2_Sensor.html
Old Dec 20, 2007 | 04:55 PM
IMALLSLO's Avatar
Code 2 is yes the secondary O2 sensor. If you dont have one just run a single wire to the added sensor on the exhaust manifold.
It goes to the C8 pin location
If you have one already double check wiring. This Ecu will not diagnose a faulty sensor,it just recognizes its not connected
Tech - PR3/PW0 Wiring
‘A’ connector (White)
N/C A15
Yel/Blk
+12V
Switched IGP1 A13
Yel/Blk
+12V
Switched IGP1 A11
Blu/Yel
Air control value
EACV (IAC) GAP A7
Yel
Injector
INJ4 A5
Lt Blu
Injector
INJ3 A3
Red
Injector
INJ2 A1
Brown
Injector
INJ1
A18
Blk/Red
GND
LG1 A16
Bro/Blk
GND
LG1 A14
Grn/Blk
Fuel pump
FLR A12
Grn/Blk
Fuel pump
FLR A10
Green
Purge valve
PCS A8
Green
VTEC Spool
VTS N/C A4
Black
GND
PG1 A2
Black
GND
PG1
‘B’ connector
B19
White
Knock Sensor
B17
White
Ignitor
ICM B15
White
Ignitor
ICM B13
Blu/Wht
+12V at start
STS B11
Black
Rear
Demister N/C N/C B5
Blu/Blk
VTEC pressure
VTP B3
Yellow
A/C Clutch
ACC B1
Wht/Grn
+12V always
VBU
B20
Brown
Adjust timing
N/C B16
Yel/Red
Speed sensor
VSS B14
Blue
Alternator
ALTC B12
White
Dist
Crank- B10
White
Dist
Crank+ B8
Blue/Red
A/C switch
ACS B6
Grn/Orge
Check light
MIL
‘C’ connector
C15
Yel/Red
MAP+
VCC1 C13
Yel/Whte
TPS+
VCC2 C11
White
MAP C9
Red/Wht
P/S
Pressure? C7
Red/Blue
TPS C5
Red/Yel
Air Temp
C3
Orange/Blue
Dist TDC+
C1
Blue/Grn
Dist CYL+
C16
White
O2 #1
C14
Grn/Wht
MAP-
SG1 C12
Grn/Wht
Sensor
GND SG2 C10
Grn/Wht
Brake Lt
C8
Red/Blue
O2 #2
C6
Red/Wht
Water T
C4
Wht/Blu
Dist TDC-
C2
Blu/Yel
Dist CYL-
Copyright © 2007 Hondata, Inc. All rights reserved.
Products are for off road use. Warranty Information
importnoodles
Mar 29, 2008 10:20 AM
AccordEX1991
Aug 6, 2007 02:49 PM
95_red_dc
Sep 11, 2006 06:32 AM
chambersef8
May 14, 2004 01:12 PM
