clutch/shifting problems
Old Mar 29, 2005 | 08:12 AM
743power's Avatar
Default clutch/shifting problems
I have been having some problems with my car lately. It is an eg with a b-series motor/trans, stock clutch and whatnot. Lately, when starting off in first, it is real rough, like there is hot spots on the flywheel and the clutch is not grabbing evenly. Also, it is REAL hard to shift the car. The clutch pedal pressure is normal, not losing pressure at all.
When I pump the clutch pedal all the way down, it is extra squeaky, and there is a click all the way at the bottom, coming from the master cylinder area. This has been going on for a week, and there is no signs of fluid leaks, which rules out the hydraulic system. Also, the linkages are tight.
Basically, I am thinking it is the clutch or the throwout bearing. My friend had a similar problem in his car and when I replaced the trans/clutch, I found that a piece of the clutch disc broke off and that was causing the springs to just flop around.
I need to get some idea about what this could be. I have another trans I can use and if it seems to be clutch/TOB/trans problem, than I will have to order a new clutch and make time real soon to fix this.
Come through for me on this one H-T.
Old Mar 29, 2005 | 09:21 AM
JimBlake's Avatar
Default Re: clutch/shifting problems (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">Basically, I am thinking it is the clutch... My friend had a similar problem in his car and when I replaced the trans/clutch, I found that a piece of the clutch disc broke off and that was causing the springs to just flop around.</TD></TR></TABLE>
Or maybe uneven glazing of the disk, PP, & flywheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">... or the throwout bearing...</TD></TR></TABLE> probably not from the sound of your description.
Old Mar 29, 2005 | 02:26 PM
743power's Avatar
Default Re: clutch/shifting problems (JimBlake)
something worth noting, when the car is cold, it shifts almost normal, noticably notchier than it should be, but no real problems going in gears. After a mile or so is when it gets bad.
Old Mar 29, 2005 | 04:07 PM
743's Avatar
743
Bump
Old Mar 30, 2005 | 04:01 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">... noticably notchier than it should be...</TD></TR></TABLE>If the disk or it's hub is coming apart, that would make the clutch drag. Whether it's uneven glazing, warped disk, or the hub coming apart; you still have to take the tranny off & look. Once you do that it's kinda silly to NOT put in a new clutch.
It doesn't sound to me like clutch hydraulics or tranny internals (synchros).
s13hero
14
Nov 21, 2010 04:57 PM
sheBangZ
Oct 16, 2007 05:04 PM
InitialJRift
Sep 13, 2006 10:43 AM
743power
Mar 29, 2005 05:40 PM
tianporn
Nov 5, 2004 12:18 PM
