clutch problems
clutch problems
problem is 3,4,5 while cruising if i floor it she'll rev up liek in neautral bu the clutch still grabs like a ****. I changed out my slave cylinder,. the master i noticed was leaking also. the clutch engages at the very top tip, is there any explanations that the cmc could be causin me to go into neutral while driving. clutch is aftermarket.
Re: clutch problems (sheBangZ)
Usually when that happens either it's the tranny popping out of gear or if it is the clutch make sure the clutch mc is good and that you bled the lines right. Also check the clutch pin that pushes the fork to make sure it's not leaking or anything from there. Then again if the fluid system isn't working it will be stuck with the clutch pressed to the flywheel and not stuck open.
So I say the problem is either yes, the clutch is slipping or the tranny is popping out of gear. I'm assuming it's the right clutch for the right motor and the clutch/pressure plate are matched for each other
