Clutch Problem (Won't engage)
Okay, heres some background: My stock b16 basically got all screwed up from being turbo'd. I rebuilt the block and just got it all back in. Started the engine up and everything seemed to be running pretty good. Now here is where the problem comes in. I can put it in gear and all, go through 1st-5th gears and reverse gear, but if I let off the clutch pedal while its in gear it doesn't move. Basically the car won't move when in gear. So I am trying to trouble shoot here. I need all possible problems/solutions.
im having the same problem but im getting a whining noise when i try to let out the clutch. I can move through all the gears but i cant engage. I think i ran the tranny without any oil in it. Could someone please help? also could it be from over filling the tranny (or soaking the clutch? thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid0006 »</TD></TR><TR><TD CLASS="quote">Okay, heres some background: My stock b16 basically got all screwed up from being turbo'd. I rebuilt the block and just got it all back in. Started the engine up and everything seemed to be running pretty good. Now here is where the problem comes in. I can put it in gear and all, go through 1st-5th gears and reverse gear, but if I let off the clutch pedal while its in gear it doesn't move. Basically the car won't move when in gear. So I am trying to trouble shoot here. I need all possible problems/solutions.</TD></TR></TABLE>
What was the problem with it? Im having the same problem right now and im hoping maybe its because i only have 1 1/2 quarts of oil in the tranny.
AH HAH. We fixed it. But there is a new problem.
</TD></TR></TABLE>you should post what you did to fix it, and what other problems you encountered!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sfwd dc2 »</TD></TR><TR><TD CLASS="quote">
What was the problem with it? Im having the same problem right now and im hoping maybe its because i only have 1 1/2 quarts of oil in the tranny.</TD></TR></TABLE> i don't think the oil has anything to do with it, you're only 1/2 qt low!
</TD></TR></TABLE>you should post what you did to fix it, and what other problems you encountered!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sfwd dc2 »</TD></TR><TR><TD CLASS="quote">
yeah i know... i filled up the oil and it still does the same. still not sure what happened. the clutch fork moves... hope i dont have to take the tranny off again!
nevermind... i found out why. My driver side axle wasn't fully in completely. I was in such a rush and so tired last night that i didn't double check everything
Modified by BoOsTiN Dc2 at 3:11 AM 4/3/2006
