clutch disengagement ?
Old Jan 28, 2003 | 05:15 PM
Kermit EK's Avatar
Default clutch disengagement ?
noticed my clutch pedal is really close to the floor when the clutch is disengaged, is this bad? Its a aftermarket performance clutch and it does have some pretty stiff pedal pressure. The clutch is not slipping but I have noticed when launching at the strip from 5k with the clutch pedal fully depressed the car rolls slightly foward. Anyone every had these problems? thanks
Old Jan 28, 2003 | 08:32 PM
Volcom's Avatar
Default Re: clutch disengagement ? (Kermit EK)
Sounds like the clutch isn't disengaging when pressing all the way in. Do you have any free play in the pedal? Mine is totally opposite of yours. Mine doesn't engage until the pedal is released about an 1 or 1.5 off of the floor. Sounds like your clutch is really never disengaging.
Old Jan 28, 2003 | 09:03 PM
Kermit EK's Avatar
Default Re: clutch disengagement ? (Volcom)
do you mean free play at the top of the pedal stroke? If so yes about a 1/2 inch or so. Man its so anoying because its hard to stage the car because it rolls. Ive asked techs and friend with shops and no one has a clue.
Old Jan 28, 2003 | 09:35 PM
Volcom's Avatar
right before i replaced my clutch, my old one was really acting funny. One of the funny things was it rolled when the brake wasn't held. After taking out the tranny and finding out what the problem was (part of the clutch was broken off and stuck in the clutch disc making it always engaged) the problem was fixed with a new clutch. However, in your case, maybe the clutch pedal isn't adjusted correctly and needs some more freeplay. I really don't have any more suggestions. sorry for not being that much of a help
Old Jan 28, 2003 | 10:02 PM
Kermit EK's Avatar
part of the disk was broken off. did your car roll just like I described above? When the car is stoped and clutch pedal is in with no brake and no gas my car doesnt move only when gas is applied around 4-5k rpm. Is this the problem you had? sorry for so may ? but I want to no if I should throw another clutch at it or maybe like you said before pedal adjustment. thanks
Old Jan 28, 2003 | 10:24 PM
Volcom's Avatar
with the bad clutch still in, the car would roll at idle. It was because that little piece was still making contact with the flywheel and partly grabbing the clutch disc. I don't know why your car would roll forward when at 4-5K. How old is your clutch? Mine had 137K on it and finally died.
Old Jan 28, 2003 | 10:37 PM
Kermit EK's Avatar
clutch has approx. 20k on it .
Old Jan 28, 2003 | 11:05 PM
viCeVerSa's Avatar
i read another thread , ........... arent most aftermarket clutches adjustable
Old Jan 29, 2003 | 06:18 AM
Volcom's Avatar
Default Re: clutch disengagement ? (viCeVerSa)
Yea, we're trying to decide if that is what he needs to do. I've never heard of a car sitting there at idle fine, and then once you rev it up to 4-5K, it rolls slowly. I'm still thinking the clutch needs adjustment. But, I don't really know how.
Old Jan 29, 2003 | 10:08 AM
Kermit EK's Avatar
I adjusted the clutchmaster from under the dash and the pedal feels way better. I will go to the track and see if it still rolls but I think the problems solved thanks for all the help
Old Jan 29, 2003 | 02:02 PM
squirrel's Avatar
I had the front of my car jacked up so could add a resonator. When I gave it a couple of revs(to hear the sound) The wheels were slowly moving, even in neutral. Does anyone elses car do this?
Old Jan 29, 2003 | 03:02 PM
jdlvl_type_R's Avatar
you probally have to much free play on it, or might need a new spring
Dre_559
May 28, 2009 08:23 PM
Tommy_Gunns
Aug 29, 2002 12:35 PM
Steve
Jul 23, 2001 01:42 PM
