Clutch pedal firmness?
What causes one clutch pedal to be firmer then another?
Two exact same clutches in the exact same car, however one has a noticably firmer clutch pedal then the other. Is it fluid level, wear, or pedal adjustment?
One thing that I noticed was that the other ITR that had the softer clutch pedal...the clutch did most of the engaging at the last 1/3 of clutch pedal travel (when releasing the clutch pedal), the car almost didn't move at all during the first 2/3 of releasing the clutch pedal. Is this normal cause my ITR starts to move at 1/4 (probably even less than that) of clutch pedal release?
Re: Clutch pedal firmness? (Tommy_Gunns)
Pressure plates usually make the difference.
One car could have an older spring (therefore easier to engage) on the clutch pedal itself.
Re: Clutch pedal firmness? (Big Phat R)
I have the older car and mine is the one that is firmer.
EDIT: Check out my grammer Ms. Edmonds (my high school english teacher).
[Modified by Tommy_Gunns, 2:55 PM 8/29/2002]
I noticed that on my friend's GS-R too. His catches lower and requires more effort.
While mine catches higher and feels like I'm pushing air.
I replaced my clutch fluid and the pedal firmed up. Maybe the other cars fluid is old/toast?
Edit for spelling....
[Modified by StageOne, 4:02 PM 8/29/2002]
BPR - who just changed his clutch b/c the engagement point was getting too high
Will
Re: Clutch pedal firmness? (Fugazi)
Re: Clutch pedal firmness? (Soup ****)
Air bubbles would make the clutch pedal softer. Mine is firmer and the other ITR is practically brand new (2001 with 14K miles).
AzntaggeR
08-08-2019 09:57 AM
