climate control problem!!!
Old Apr 28, 2009 | 08:55 AM
NiKKa NiKKy's Avatar
Default climate control problem!!!
okay my climate control light all works, but air doesnt blow out when i turn it on, and my rear window defrosters don't work. i've taken off my climate control to check the wirings and they seem fine, i really don't know what else to do, its been raining all week and i can't see when i drive cause i have no defrosters front and back!!! lol, and i keep blowing a fuse for my passenger side window whenever i put a new fuse in, i know theres a short but damn i cant find that wire short anywhere!! no ac, and windows not working in texas weather is killer!!
Old Apr 28, 2009 | 10:09 AM
dtapia's Avatar
Default Re: climate control problem!!!
so what type of car is yours ?
Old Apr 28, 2009 | 04:51 PM
fcm's Avatar
fcm
Old Fart
Ditto that^^^.
MM&Y of car please. 94
Old May 1, 2009 | 09:42 AM
lol oh yea, my bad, got so into the problemforgotto statethat,its a 94 integra lol.
Old May 2, 2009 | 10:01 AM
fcm's Avatar
fcm
Old Fart
The rear window defrost is controlled by the ICU.
For the front the first thing I would check is the blower motor, test the blue/white lead at the blower motor two pin plug, it should test as 12V+ when ign. switch is in the run position.
If there is 12V+ at the blue/white lead, [with ign. on] use a jumper wire to supply a direct ground to the blue/black lead, stuff one end of jumper into plug with blue/black lead/terminal and touch the other end of jumper to any chassis ground point, does blower motor work? 94
Old May 4, 2009 | 10:00 AM
thanks i'll try it,im not a real tech head but ill try lol
Old May 5, 2009 | 05:30 AM
you know how the lights are supposed to come on when you press a button, none of them do either
Old May 5, 2009 | 09:01 AM
ironcheftony's Avatar
check ur relays under the engine bay fuse box, those go bad
Old May 5, 2009 | 10:51 AM
fcm's Avatar
fcm
Old Fart
They are LEDs and it is unlikely they are all blown, check fuse 17 - 7.5A, [hot in run] in under dash fuse box.
Do any of the indicator lights, [or illumination lights] work in the climate control head?
Did you try what I suggested with the blower motor?
If so, what did you find? 94
woody7121
May 12, 2015 04:03 PM
Homotor
Jan 26, 2009 11:52 AM
mormonboy
Sep 7, 2007 10:24 PM
chuniepatuni
Jan 3, 2007 07:16 PM
crazydragonclk
Jun 1, 2006 09:42 AM
