climate control problem
ok.. i took out my climate control to change the lighting to amber and when i put it back in it only stays on one setting on the head and feat icon, i can adjust the heat and the blower. i cant use my defroster or anything else, i thought it would be a fuse but i checked for that and it seems that there is not a fuse for that and then i thought it would be a relay but i dont know where it is. HELP ME H-T!!
Re: climate control problem (chuniepatuni)
Up to top...
Im currently having similiar problems.
Heater doesnt work. Adjust to hot side, still blow cold air
Stays on 1 setting . the 1 towards your face.
I cant adjust the blower.
is it there a relay? my heater Blower is out?
Help if you can
Help if you can
Re: climate control problem (BlackSheep209)
you might need to get a new climate control unit cause the board might have gotten screwed up for the blower, for the heater check the wire that runs from the climate control to the bottom of the glove box but as far as the setting i dont know what to do
Imperious: Mod of Valor
I had the same problem, I forgot to plug one of the harnesses together that controls that function. I know it sounds silly, but I this is the last thing I checked when I had this problem; when it should've been the first.
Re: climate control problem (JDM-EJ1)
i know i have all the plugs plugged in cause i took it out about 4 times to check.. the green plug and the clear plug are the only two plugs that need to be plugged in
I dont think its my climate control niether, I thought that was the problem. so i used another climate control that i had, and its still has the same problems.
CincyCichlids
07-21-2010 11:42 PM
civhatch90
10-31-2006 03:04 PM
DC2uNer
03-08-2004 01:10 PM
