need help with climate control and defrost
Old Jan 25, 2009 | 08:44 PM
Homotor's Avatar
Default need help with climate control and defrost
hello i got into my car this morning and went to turn on my heater and my defrost and nothing happend? when i try to move it frm 1-4 it doesn't blow anything, and when i press a button on the climate control none of the lights light up same with defrost, but when i turn on my lights all the dash lights on the gauges, climate control, and defrost come on but won't work when i try to turn on the heat or defrost my rear window... i need helpp its been awfully cold driving to work every morning and having to roll the window down so it can defrost, i was thinkin maybe a fuse? any help would be greatly appreciated
Old Jan 26, 2009 | 06:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: need help with climate control and defrost
MM&Y of car would help. 94
Old Jan 26, 2009 | 09:07 AM
Homotor's Avatar
oh sorry, its a 92 civic hb cx
Old Jan 26, 2009 | 11:52 AM
fcm's Avatar
fcm
Old Fart
HVAC control head, [heater controls] illumination is a different circuit then the controls themselves, blower motor will have it's own fuse, the control only supplies the ground to the blower motor,
same with other function, the control head supplies grounds to the "Mode Control Motor" it has it's own fuse.
I would be checking fuses and dash harness plugs, remove HVAC control head and make sure it is pluged in properly, you may be able to access the HVAC plug(s) by removing the HU.
Make sure all plugs are properly plugged into the fuse box. 94
delsolo95
Honda Civic (2006 - 2015)
Dec 17, 2012 05:33 PM
96Formula6spd
May 21, 2011 04:44 PM
CincyCichlids
Jul 21, 2010 11:42 PM
mormonboy
Sep 7, 2007 10:24 PM
4drRacer
Aug 3, 2002 11:30 PM
