Cleaning Block And Head...
Old Aug 11, 2003 | 09:34 AM
LudeyKrus's Avatar
Default Cleaning Block And Head...
I'm needing to clean out my block and head, since I am doing a rebuild and did a little port-n-polishing, I need to clean out the metal flakes/grit. I searched and saw people recommend brake cleaner, and someone else suggested water and soap. I don't want the mess of brake cleaner, and wouldn't water and soap cause things to start rusting? I'd have to oil it all back down, right?
I was thinking of using gasoline, but that doesn't seem like it'd get the flakes very well.....any suggestions?
Old Aug 11, 2003 | 10:39 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Cleaning Block And Head... (LudeyKrus)
Bump cause I need some stuff to remove my HG.
Blaze
Old Aug 11, 2003 | 10:51 AM
michael O's Avatar
I used brake cleaner but it was taking too long so I just brought it down to a machine shop and had them hot tank it. I should be getting it back soon.
Old Aug 11, 2003 | 03:42 PM
allwheelerman's Avatar
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">I used brake cleaner but it was taking too long so I just brought it down to a machine shop and had them hot tank it. </TD></TR></TABLE>
and it shouldnt be very much. 60 dollars or so if the head and block are bare
Old Aug 12, 2003 | 07:42 PM
WOTTEG's Avatar
Acetone.
Go to a beauty supply store and get a big bottle of PURE Acetone.
Works great and most importanly EVAPORATES QUICKLY.
I use this when I need to clean/prep aluminum.
Old Aug 12, 2003 | 07:56 PM
JDMHN8's Avatar
Default Re: Cleaning Block And Head... (WOTTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WOTTEG &raquo;</TD></TR><TR><TD CLASS="quote">Acetone.
Or you can go to Home Depot and get a gallon tin jug of Acetone for what I would imagine would be less than a beauty store.
Old Aug 12, 2003 | 08:41 PM
LudeyKrus's Avatar
I'll try acetone next time, it should be much easier.
I took it outside, sprayed it down good w/ soapy water, let it drain out and sprayed WD-40 on it all the while; motor oil went on as soon as it completely dried out.
Old Aug 12, 2003 | 08:50 PM
HEAD's Avatar
take a air chuck and blow out some of the debris, then squirt the head down with water( it will get the seats rusty only if you let the head sit to long)I wouldn't use soap that would make a real mess, then get your brake clean and quickly shoot the head down with it-use the whole can if you want this will make the head much easier to dry and it won't leave a residue and then take out you air chuck and blow the head off until dry.
Or just spend the money and take it to a machine shop and let them do it, it will probably come out cleaner to.
itr#1334
Oct 13, 2008 08:47 PM
9hatch6
Sep 11, 2006 12:30 PM
putitinthebucket
Oct 26, 2005 11:06 PM
the DA in HONDA
Oct 21, 2004 04:59 PM
see_our_vtec
Dec 1, 2003 07:37 PM
