CKP/CKF trick issues
this is the first time I'm running into this issue on an obd2a computer I've tried the instructions listed here...http://technet.ff-squad.com/ckftrick.htm with no luck...key on, engine off the check engine light comes on and goes off like normal, but as soon as I start it the light comes on and I am getting a code p1337 CKP sensor 2...any one have any ideas?
vehicle is a mostly stock 1997 GSR, with a US 1995 GSR engine...intake manifold and sensors/wiring harness from the 1997 motor were swapped onto the 1995...I should have just swapped the oil pump when I had the motors out of the car, but I figured this trick would work and didn't feel like taking the time since I will only have this car running obd2 for emissions
any ideas guys? any one have any info on the p1337 code? I need to get this fu*ker through emissions
oilspot
Feb 24, 2009 10:16 AM
VTECVillain
Jul 6, 2002 09:28 AM
