chrome & idle problems?
Old Oct 8, 2005 | 07:01 PM
turboB16RFD's Avatar
Default chrome & idle problems?
What's up.. I'm running Chrome on a turbo b16 .. it is great, except at idle, sometimes it fluxuates rpm's from between 500 - 1000, or 800-1200... and sometimes it just goes down really low and feels like it's about to stall
Is anyone else having this problem? Any help appreciated!
Old Oct 8, 2005 | 08:45 PM
drdisco69's Avatar
Default Re: chrome & idle problems? (turboB16RFD)
Is it tuned, and do you have a wideband in the car?
Old Oct 8, 2005 | 09:08 PM
Default Re: chrome & idle problems? (drdisco69)
yes it is tuned .. and the wideband was in the car when my boy tuned it, but it is no longer in the car.. should it be?
Old Oct 8, 2005 | 09:47 PM
drdisco69's Avatar
It's just helpful to see the AF ratio to diagnose things like this. I've found that the motors are more tolerant of rich AF ratios at idle than lean, so a guess would be add fuel in the idle region, but it's just a guess. When the car was tuned, did it idle ok?
Old Oct 9, 2005 | 09:15 PM
mtber's Avatar
My guess is this has to do with your "boy" tuning it.
Have him check all the high vacuum (idle) ; low cam ignition tables up to 1200 rpms.
Set them at the same amount i.e. 16.5 deg etc...
Also, play with the idle set screw on the throttle body.
ciiivic89
Feb 9, 2009 07:03 PM
94typeR
Mar 28, 2007 05:49 AM
brad98_teg
Nov 10, 2006 01:30 PM
Hyaboosta
Jul 13, 2005 02:14 PM
Brian_92GSR
May 31, 2004 03:57 PM
