Checking for bent valve
Old Jan 18, 2009 | 02:49 PM
kinkyintegra's Avatar
Default Checking for bent valve
Is it possible to check for a bent valve if the head is off the motor...i know i can do a leakdown test but I have a head thats currently off the motor just wanted to make sure the valves are good. Same question to see if piston rings are bad. I had low compression in one of the cyclinders so I want to make sure its one of those. Thanks for the help.
Old Jan 18, 2009 | 04:13 PM
NJIN BUILDR's Avatar
Default Re: Checking for bent valve
You can pour liquid down the port.If it leaks past the valve than that's the problem.Many shops have a vacuum tester that will work too.It's a lot harder to tell if it's the rings if your not used to inspecting them.Make sure they are not stuck in the grooves.They shouldn't have any slop up and down in the grooves though.
Old Jan 18, 2009 | 04:17 PM
SP GARAGE's Avatar
dont use water.... use rubbing alcohol it works great.
mayfly
Jun 16, 2012 06:02 PM
dem0nk1d
Apr 15, 2011 08:35 AM
KoRE
Apr 13, 2010 09:40 PM
integra123
Sep 25, 2008 09:09 PM
89sicivic
Feb 2, 2006 08:45 AM
