Check a code on a OBDII?
Old Jan 5, 2003 | 05:41 PM
Grimm's Avatar
Default Check a code on a OBDII?
How can i check what code is being thrown on a OBDII ECU for a 98 GSR? Thanks in advance.
Old Jan 5, 2003 | 08:09 PM
sgT's Avatar
sgT
Default Re: Check a code on a OBDII? (Grimm)
theres a little 2 pin plug under the dash by the glove box.
short that connector and the check engine light will blink.
long blink - 10s
short blink - 1s
Old Jan 6, 2003 | 06:21 AM
Grimm's Avatar
Default Re: Check a code on a OBDII? (sgT)
Thanks...
then i will just need to know what code goes to what problem.
Old Jan 6, 2003 | 06:27 AM
Spade's Avatar
http://www.hondata.com/techecucodes.html
Old Jan 6, 2003 | 07:12 AM
qcoffey's Avatar
Default Re: Check a code on a OBDII? (Spade)
Someone gave me this site and it helped out tremendously.
http://www.jdmfan.com/technical/other/troubleshoot_dtc/
Good Luck.
Old Jan 7, 2003 | 07:31 AM
Grimm's Avatar
Default Re: Check a code on a OBDII? (qcoffey)
Thanks that site was helpful, showing the connectors and such. Mt final question is, I shorted the wires, and now when I turn the ignition "on" but don't start the car it blinks once and it is what I would Imagine a long blink. But when I actually turn over the car and start it it continualy blinks at the ame rate? would it be the first code when the car isn't running?
Old Jan 7, 2003 | 07:41 AM
Spade's Avatar
Correct the on position do not start the car.
What was the code it gave you before starting the car?
Old Jan 7, 2003 | 08:04 AM
Grimm's Avatar
one long blink I think? only seeing one blink makes it hard to determine if it was the long or short one. But it definatly wasn't really quick
Old Jan 7, 2003 | 08:06 AM
Spade's Avatar
Yuck....ECU usually. Try to find a local H-T'er that will let you borrow theirs for a few hours to test on your car.
EDIT: WRONG WRONG SPADE.....Solid light is ECU......THINK first ya boob.
[Modified by Spade, 9:50 AM 1/7/2003]
Old Jan 7, 2003 | 08:23 AM
Grimm's Avatar
I thought that was an intake temp sensor. Code 10?
suprant0010
Apr 19, 2014 02:41 AM
Leets
Mar 25, 2002 08:41 PM
SlowB16
Mar 4, 2002 05:20 PM
b18civic
Feb 18, 2002 03:58 AM
b18civic
Feb 12, 2002 03:48 AM
