Head rebuild need help with a quick question please read...
Old May 25, 2003 | 07:43 AM
ludesleep's Avatar
Default Head rebuild need help with a quick question please read...
I dropped off my head to be resurfaced and tanked. The machine shop needs new valve seals before they install my valves. I checked hondaautomotiveparts.com and they list four types of valve seals. Two "Valve A's" & two "Valve B's", im assuming that both a's are the same as are the b's. My question is do I order one set of each A&B?
THanks
Bobby
here is the link, its numbers 4&5
http://www.hondaautomotivepart...82%29
Old May 25, 2003 | 11:17 AM
IN VTEC's Avatar
Default Re: Head rebuild need help with a quick question please read... (ludesleep)
You need a set of A's and a set of B's. The A's are for the intake side, and the B's are for the exhaust side.
You can also distinguish b/w the IN and EX sides by looking at the spring color on the valve stem seal. IN - white, EX - black.
court76wi
May 22, 2010 03:00 PM
projectTeG
Mar 31, 2010 06:24 PM
Grandprix
Nov 7, 2003 05:25 PM
ludesleep
May 27, 2003 10:48 AM
