CEL code 1456?
Old 06-25-2003, 09:37 AM
AamirCWITR's Avatar
Default CEL code 1456?
Anyone know what this is? And does anyone have any further information regarding causes and solutions.
Thanks
Aamir
Old 06-25-2003, 11:04 AM
untitled's Avatar
Default Re: CEL code 1456? (AamirCWITR)
what?
Old 06-25-2003, 11:05 AM
Katman's Avatar
uh...
no such thing as code 1,456. lol
do you mean:
code 1
code 4
code 5
code 6 ?
Old 06-25-2003, 11:38 AM
EE_Chris's Avatar
Default Re: CEL code 1456? (Katman)
Put a "P" in front of 1456....is it now a code?
Old 06-25-2003, 12:06 PM
Katman's Avatar
Default Re: CEL code 1456? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Put a "P" in front of 1456....is it now a code?</TD></TR></TABLE>
l337 translated = piasg ?
Old 06-25-2003, 12:17 PM
EE_Chris's Avatar
C'mon Katman...I know you've heard of "P" codes before. If it is a "P" code, I'm not sure of what it is though....only saying that its a possibility.
Old 06-25-2003, 12:35 PM
JimBlake's Avatar
P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
This is the one you get when you forget to tighten the gas cap. But there's other things that can cause it, too.
Bad gasket on the gas cap, so it's not airtight? Basically, anything that can cause your gas tank to be NOT airtight. There's gaskets around the openings for the fuel pump or gas gauge sender. There's a bunch of tubing connections, including the filler pipe, EVAP system connections, gas tank pressure sensor fitting, fuel return hose from the FPR, probably a bunch more, too.
Old 06-25-2003, 12:49 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">C'mon Katman...I know you've heard of "P" codes before. If it is a "P" code, I'm not sure of what it is though....only saying that its a possibility.</TD></TR></TABLE>
lol....actually I haven't heard of the P codes ..
Old 06-25-2003, 01:26 PM
JimBlake's Avatar
They're OBD-II codes. That's what you get when you plug in a fault code reader, like they do at AutoZone. For each Pnnnn code, there's a flashing-CEL code that corresponds to it. But sometimes 4 or 5 Pnnnn codes are all represented by the same flashing-CEL code, so the Pnnnn codes are more specific.
Just depends on which method you use to read the fault code.
Old 06-25-2003, 01:30 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AamirCWITR &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know what this is? And does anyone have any further information regarding causes and solutions.
Thanks
Aamir</TD></TR></TABLE>
What year and model? And mileage?
Old 06-25-2003, 04:10 PM
Katman's Avatar
Default Re: CEL code 1456? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">They're OBD-II codes. That's what you get when you plug in a fault code reader, like they do at AutoZone. For each Pnnnn code, there's a flashing-CEL code that corresponds to it. But sometimes 4 or 5 Pnnnn codes are all represented by the same flashing-CEL code, so the Pnnnn codes are more specific.
thanks....did not know that.
Eddie99
Honda S2000
11-07-2007 09:31 PM
jravensc
04-29-2007 01:36 PM
teler86
12
02-20-2007 01:46 PM
Quick Reply: CEL code 1456?
