throwing cel
Old Nov 4, 2003 | 04:02 PM
tegon-gsr's Avatar
Default throwing cel
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
* invalid code for non-VTEC engine what do i have to buy or how can i fix it???
Old Nov 4, 2003 | 04:24 PM
mikeyy's Avatar
Default Re: throwing cel (tegon-gsr)
idk about fixing it, but you can just disconnect the negative terminal on the battery, and the cel will go off.
Old Nov 4, 2003 | 07:53 PM
WiggiE's Avatar
New User
So is your car throwing the VTEC oil pressure switch code and you don't have VTEC?
Old Nov 5, 2003 | 04:03 AM
tegon-gsr's Avatar
Ok i have vtec i have a 1995 gsr but im throwing that code when that happens it cuts off my vtec in high rpm area and wont let me rev up to 8000 it will cut me off around 6000 now is the switch something i can just go and buy and switch up or is it more complicated that???
Old Nov 5, 2003 | 05:12 AM
WiggiE's Avatar
New User
Check your oil and make sure it is filled to the top of the hash marks on the dipstick.
Old Nov 5, 2003 | 07:16 AM
integraL's Avatar
Default Re: throwing cel (WiggiE)
it says switch defective or unplugged. check if that green thing on the left of your motor is plugged
Old Nov 5, 2003 | 11:54 AM
Kazz's Avatar
Default Re: throwing cel (integraL)
did you install a vtec controller or anything?
Old Nov 5, 2003 | 02:27 PM
WiggiE's Avatar
New User
Default Re: throwing cel (JuuKe_EM)
Does your VTEC work some of the time, or not at all?
Old Nov 5, 2003 | 03:55 PM
tegon-gsr's Avatar
yes i had a vafc install about 3 months ago i check all wires and they were fine its not the oil cause i had it fill all the way up it comes on sometime not always though. after a couple good runs it will come on or if im on the high way about 75-80 it will come on.
Old Nov 5, 2003 | 06:18 PM
WiggiE's Avatar
New User
My guess is one of two things:
1. Bad wiring to the VAFC and is an intermittent problem.
2. The wiring to the VAFC shorted out a connection in the switch.
How did you check the wiring for the VAFC, visually or by some sort of gizmo?
I would check the settings in the VAFC and make sure everything is set right. Check the wiring order going into the VAFC. And last check the wiring with a voltmeter.
Old Nov 5, 2003 | 08:10 PM
tegon-gsr's Avatar
Thanks for the info i have to get someone else to check out my wires to see if they look ok then but i here diffrent this from alot of people some say vtec pressure switch so say vafc i dont know what to belive now???
Old Nov 5, 2003 | 08:16 PM
WiggiE's Avatar
New User
Well, if it started right after the VAFC was installed, then I'd blame it on the VAFC and installation.
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
tamadrummer1120
Sep 17, 2009 09:20 PM
cioli
12
Feb 26, 2006 08:31 AM
drudy
Aug 7, 2005 05:59 AM
EKweezy
Jun 25, 2003 02:35 PM
