just got Vision oil catch can...about to install but....
....some things are puzzling me.
For example , the pipign will run from PCV , to the can inlet , then another hose will contuinue back to the inlet manifold . All fine and dandy. But , how do i remove the piping from the PCV and oinlet manifold easily / without damaging it? After removing the small clips , it will not budge with any effort ?!? Any hints ?
Also , is this catch can internally baffled / filtered inside ?
If not , is there a good DIY way to insert some steel wool etc ?!?!?
Any guides...cheers Ben
Mr. Badwrench
Re: just got Vision oil catch can...about to install but.... (bennjamin@ozhonda.com)
get a pick tool and some wd40. get under the hose and hit it with the wd and it should slide right off. as for if it is baffled or not i am not sure.
schpiel
07-09-2007 08:57 PM
