car wont start
Old Aug 8, 2003 | 11:04 PM
gumbybum's Avatar
Default car wont start
ok i had just finished my s2k antenna install and had my car running just at idle in neutral when it died. i thought it was just the batt. but it wasn't, im thinking something in the fuel line because it will crank and turn over just no start... when it turned off it was like i had run out of gas but i have a 1/4 of a tank. i also checked fuses and checked everything i could think of but im stuck. please help me
PLEASE i am supposed to go pick up my tranny tomorrow night but i wont be able to with my piece of **** car not running....i guess this is what i get for helping my friend work on his car all day its like i have reverse karma
_______
Old Aug 8, 2003 | 11:19 PM
gumbybum's Avatar
Default Re: car wont start (gumbybum)
help me....
Old Aug 8, 2003 | 11:23 PM
mmuller's Avatar
Mad Scientist
checked for spark?fuel?is the fuel pump priming when you turn the ignition on?
Old Aug 8, 2003 | 11:34 PM
gumbybum's Avatar
Default Re: car wont start (mmuller)
this may sound rediculous but how can i check if its priming? i dont think that there is any fuel getting to the motor-basically no combustion..
Old Aug 8, 2003 | 11:47 PM
mmuller's Avatar
Mad Scientist
turn the ignition on(without cranking)and listen by the rear seat.it should make noise.
Old Aug 9, 2003 | 10:11 AM
gumbybum's Avatar
i havent checked but i dont think it is..i dont remember it doing that so what do i do if it its not? does that mean that there is a problem with the fuel pump? im going to check it anyway...thanks man
Old Aug 9, 2003 | 01:45 PM
gumbybum's Avatar
yeah is priming but i also took it out to see if i could find any problems with it and i coulnt see any. i am almost positive that the problem lies within the fuel delivery or something in the fuel line but i guess icould check my plugs too. any oher suggestions? please i need my car by tomarrow..
Old Aug 9, 2003 | 02:04 PM
.Noah Fecks's Avatar
take out the plugs. i thought i had the same problem i bet you thats what it is
Old Aug 9, 2003 | 02:21 PM
gumbybum's Avatar
Default Re: car wont start (Noah *****)
ok thans man, im going out side right now....i pray that this is the problem
Old Aug 9, 2003 | 05:02 PM
gumbybum's Avatar
ok i have no idea what it is at all, i changed the plugs, checked fuses, checked the pump, checked the dist. and checked the wires....come on please help me out
PLEASE help me
Old Aug 9, 2003 | 06:58 PM
gumbybum's Avatar
ok i checked the T belt and it was fine, but then i checked the spark and there was none..so what do i do now??? i have alrady checked the dist. and it looked fine so what should i do?
Old Aug 9, 2003 | 11:16 PM
Stripped Honda's Avatar
99-0104
go buy a new ignitor that is the problem if there is no spark and your timing belt is ok
Old Aug 10, 2003 | 04:57 PM
mmuller's Avatar
Mad Scientist
Default Re: car wont start (Stripped Honda)
check the coil
Finchms
Mar 26, 2012 03:10 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
silverboost
15
Mar 13, 2006 10:15 AM
gumbybum
Aug 11, 2003 04:38 AM
N1NjA TuRtLE
19
Oct 11, 2002 07:41 AM
